W211 HID not working
Old 11-05-2012, 02:50 AM
mollymac's Avatar
Default W211 HID not working
Hi
I have a RHD ( UK based) 2006 E320 CDI sport with what I assume are factory-fit HID Headlamps. DS1 35w Phillips Bulb and Ballasts
The drivers side dipped headlamp is off permanently. I have swapped the bulb and base unit ( I believe this is referred to as the ballast) with the working side but that still doesnt work so I have eliminated the bulb and base unit. I have tried locating the fuse but it doesnt show on the MB Fuse diagram. I then assumed the fuse would be located in the engine compartment fuse box ( as MB do not show that in their fuse chart) but all those fuses are Ok.
Also the ballast unit on the non-working side does not locate within the headlamp unit with a solid twist and click as with the other side
Can anyone help ?. Just so you know I am not that technical
Thanks in advance
Paul McG
patricknif
03-04-2012 06:38 AM
Paul Dalton
02-07-2012 02:37 PM
87MBZTurbo
08-30-2009 06:06 PM
laser_doc
11-04-2008 05:39 PM
chicagoc320wagon
07-29-2008 10:13 AM
Quick Reply: W211 HID not working
