2007 E350 - Fuel Smell & Worn Balance Shaft Sprocket
Old 03-04-2012, 06:53 AM
haegs's Avatar
Default 2007 E350 - Fuel Smell & Worn Balance Shaft Sprocket
Came back to Mercedes in Nov. purchasing a used 2007 E350 with less than 30k miles - out of warranty and no CPO. Right out of the gate - problems with fuel smell when gas tank was full. Dealer first replaced seals on fuel tank and then the fuel senders to address issue. Now the CEL has come on and independent replaced camshaft solenoid adj. and within 1/2 mile of leaving CEL came back on. Now looking into worn sprocket as outlined by Mercedes service bulletin.
I understand this is bad and would appreciate any insight as to how bad. Both on initial cost (will MB cover out of warranty) and on what other damage may have been done w\ metal shavings circulating in the oil. Just not sure what else to expect down the road
Thank you
Old 03-19-2012, 02:03 PM
Danger63's Avatar
Have the Car inspected by someone that has a clue, the guy replacing the solenoids does not have one.
Take it to a Benz specialist, depending on how bad it's worn it either needs the Intermediate gear, shaft replaced or if worn minimal a software flash can make up temporarily for it.
Good Luck, Dan The German Man
Old 07-06-2016, 04:51 PM
roger1966's Avatar
Have the same problem with balance shaft , means engine coming out to replace merc quote is £4900 merctech have quoted me £2100. car has only done 88,000 miles on a 56 plate so not sure why it has worn.
Old 12-13-2018, 10:22 AM
My car has been having a high smell of gasoline for quiet a while after I fill up my tank.
It crank but does not start! !!
ChefbenzE350
08-14-2019 03:40 PM
Avg_Joe
01-21-2016 09:24 AM
Benz_ema
01-10-2013 04:01 PM
jzlin88
08-06-2011 04:36 PM
hooper
12-28-2008 01:03 PM
Quick Reply: 2007 E350 - Fuel Smell & Worn Balance Shaft Sprocket
