Help E350 w211 gearbox ESP steering fault
Old 08-26-2011, 03:06 AM
Gwa666's Avatar
Default Help E350 w211 gearbox ESP steering fault
Hi
I need help with my 2005 e350
Problem started with it going into limp home
Won't change gear
ESP abs light is on dash
Steering very heavy now
Had this put on Diag and only fault it comes up with is check control unit n47-5 ESP pml fault does this mean the control unit is faulty
I had been told it was a fault with trans control unit but don't know what to believe now
Please help
Cheers
Steve
Old 10-30-2018, 08:00 PM
SS-CALIF's Avatar
I have the same problem with my 2006 E350. Was this resolved?
Old 12-18-2018, 12:08 PM
I need help on below points as facing problem at my 2010 Mercedes Benz E350
Oil pressure building too slowly, allowing for movement between the crankshaft and crankshaft bearings
Old 12-18-2018, 03:06 PM
Hello and welcome to the forum! Before you spend any money on parts, I would suggest pulling the car's codes to see what comes up. This will be a good indication of where the issues are coming from Please let us know if you have any other questions. Thanks!
Gwa666
01-28-2019 01:00 PM
Old Bertha
01-08-2019 01:42 PM
Mairtín
06-19-2018 03:52 AM
Avg_Joe
05-09-2012 09:11 AM
Quick Reply: Help E350 w211 gearbox ESP steering fault
