HELP - Mercedes E shutting itself off
Old 03-19-2010, 04:00 AM
aetanner's Avatar
Default HELP - Mercedes E shutting itself off
I do not have much expertise in Mercedes cars. I am writing about a problem I had and would appreciate your guidance.
I bought a Mercedes E220 CDI, with automatic gearbox, and I have been driving it since then, although so far I have only made around 25,000 km. In the past I had a problem with this car, where after I start the car and shift the gear into D, the gear would get stuck and would not change up. Hence the car would not accelerate. In such cases, after I stopped the car, and put the gear to P and then back to D the problem would go away. In any case, I mentioned this to the garage when I took the car for service, and they said "there was a leak" and they fixed it. For a while, I did not have this problem.
Recently I was driving (at around 40 km/h) on a deserted road on a rainy day and it seemed that I had the same problem. I thought, rather than stopping the car, if I shifted the gear from D to N, and then back to D, the problem would be solved. Instead, as soon I pushed the gear the car started chocking and it stopped, and the engine shut itself off.
After this incident, the car started normally and I continued to drive without a problem.
Since then a number of questions are haunting me:
Is it normal that the car would shut itself off if the gear is shifted to N from D while driving?
Is this a sign of a bigger problem? (You can imagine what trouble this can cause in traffic.)
Have I damaged the car by trying to shift the gear to N while driving?
What can I do to ensure that this problem is not repeated, so that no harm is done to myself and my family?
I will go to a Mercedes garage but I am concerned that I may not find someone who would patiently listen to a novice like myself. So any thoughts would be appreciated.
Thanks!
Old 03-19-2010, 04:01 AM
aetanner's Avatar
Sorry, I forgot to mention that I bought the car in 2006. So it is not even four years old.
Don's ML
07-26-2012 10:25 AM
GARY476
01-20-2010 07:46 AM
bootsie
09-18-2009 08:09 PM
rcrochet
09-30-2008 07:23 AM
SEmerson
10-09-2006 11:34 AM
Quick Reply: HELP - Mercedes E shutting itself off
