ignition key..... help....!!!!!
Old 04-23-2010, 05:56 PM
novato's Avatar
Default ignition key..... help....!!!!!
I have a 2001 E 320 and this morning I tried to start the vehicle like usual and when I inserted the ignition key it did not make the usual sounds and could not turn ignition switch over. it stays locked ! went and bought new batteries for the master key, but nothing...... it seems that it does not recognize this key anymore !! can anybody give me an idea of what it could be?
Old 04-23-2010, 06:01 PM
chassis221's Avatar
car battery is weak or a bad remote
Old 04-23-2010, 06:20 PM
novato's Avatar
the car battery is one month old......do you think is the master key ?
Old 04-23-2010, 07:28 PM
chassis221's Avatar
if you have a spare try it...try puttin a charger on the battery and then see if the key turns
Old 04-28-2010, 07:12 AM
Scuddog's Avatar
Smile Try something else
I don't think the problem is your key. When you put the new batteries in... and you press one of the buttons... do you get the red light blinking on the remote to let you know that you have power? If your remote is showing signs of life and you still can't turn the key... try the charger idea. It may be coincidence that you have a new battery and now nothing works... Just a thought. My guess is battery issues. Good luck!
Old 04-29-2010, 08:40 PM
novato's Avatar
you guys are awesome !! it was a loose connection on one of the car battery leads...... thank you for guiding me in the right direction !!!
Myran
12-06-2018 03:17 PM
71280sl
10-04-2010 11:38 AM
brantchastain
10-02-2010 06:17 PM
Benz_190
09-25-2005 02:10 AM
Quick Reply: ignition key..... help....!!!!!
