Pesky messages
Old 08-18-2010, 09:50 PM
ferranrico's Avatar
Default Pesky messages
I have a 2004 E320. I am a DIY
How do I erase/reset the pesky messages that keep popping up at startup even after service has been performed?
Like:
"brake service required" (I've changed brakes and wear sensors)
"service required exceeded by xxxx miles",etc
I'm also getting a red battery-"visit workshop".. display, checked the battery and alternator and they work/read fine, any ideas?
Old 08-19-2010, 01:49 AM
raymond~'s Avatar
basic, low level diagnostic trouble codes may be resettable using a higher grade OBDII
code reader. some require advance level code diagnostic tool such as those with
software and laptop combination. high level DTC are only done at the dealer (or indy)
using the SDS multiplexor.
i think brake can be done by good ODBII reader.
i'm guessing that by the time 2004 rolled around, the service required msg is dealer/SDS
DTC algorithm is usually set up to react only when the trouble has been detected on numerous
occasion, so as not to display false positives. thereafter, if the condition has been fixed,
the system may reset itself (turn off msg) only after x number of miles and/or Y number of
days.
i'm a DIYer so i'm not an expert on these things. but I do read the forums. here is a good
source of DTCs. within the first dozen pages is primer on how DTC are polled, interrogated,
displayed, and extinguished.
http://www.autoenginuity.com/dloads/...user_guide.pdf
Old 08-19-2010, 07:08 AM
ferranrico's Avatar
Thanks Raymond
I'll check out what you're suggested.
I'm looking for a way to get into Command from the dash display and steering wheel buttons.
A while back a tech at MB showed me how, but I forgot... something about the doors closed, key in ignition to #2? position, pressing the reset button. and something else and then the deeper menu appears...???
Any ideas?
Old 08-19-2010, 06:53 PM
waybomb's Avatar
How did you check the battery? When was the last time you replaced it, and what did you replace it with? You'd be surprised what a failing battery can cause on these cars.
Old 08-19-2010, 07:43 PM
chassis221's Avatar
there is no tool to erase brake messages, its either the pad wear indicator or in your case with the 2004 E you might have a bad stop lamp switch or a defective SBC brake unit that should be covered under warranty.
Old 08-20-2010, 07:57 AM
ferranrico's Avatar
Default Pesky messages 2004 E320
Took it to Advance Auto Parts and they hooked up a reader directly to the battery, apparently it reads battery condition and alternator output. The battery read 600 cold amps and 1000 cranking amps, cells read ok. The alternator performed well at idle, rev-up and a/c - bright lights load. Unless MB measures something else? or does it different?
The brake wear sensors were replaced when I did the brakes, funny, there's only one for the rear.
Is there still any warranty left on a 2004?
Old 08-20-2010, 09:48 AM
chassis221's Avatar
there is warranty for the SBC brake unit, but your car is out of the factory warranty. the battery light could be just an auxillary battery. ive seen people drive with that battery warning on for years. most of the benzs now only have 1 brake wear sensor on the back.
Old 08-20-2010, 11:43 PM
raymond~'s Avatar
thanks, chassis. i shouldn't try to type so early in the morning
  #9
Old 08-21-2010, 08:58 AM
ferranrico's Avatar
Default Thanks
You're right Chassis... there is the aux battery... I'll get it checked.
I guess that I'll have to fork over the $$$$$ to the MB screwshop to get the messages erased.
Thanks for all of ya'lls help.
I like this forum.
Regards
ferranrico
03-13-2017 01:54 PM
stevec230k
01-10-2010 11:19 PM
sea_bird200
09-26-2008 08:37 PM
E500newbee
01-01-2008 11:19 PM
Sprint97
04-18-2006 10:43 PM
Quick Reply: Pesky messages
