mis fire and sluggish to start
Hi I have a E200 98 pertol auto and it is making some misfiring noise when it drops a couple of gears when overtaking.
Firstly it kinda hesitates and then give 2 or 3 misfire from under the bonnet, I have changed the lamda sensor and the air mass meter sensor as they were showing up incorect, and also a new set of plugstill no differance, also since then when you start the car up when you put it into drive from park and put your foot on the accelerater it takes about 2 seconds before it will do anything and then it kicks in, any ideas what to do next , thanks [:@] daveaball@gmail.com
RE: mis fire and sluggish to start
Sleepwalker is correct .. best to read actual values to determine what's going on.... you may have a faulty coil.... reading the values would certainly give you more insight to what's going on.
Cheers,
TJ
Lion Heart
06-03-2013 04:59 AM
InkBlue
06-20-2006 03:14 PM
moonbike
10-24-2004 02:13 PM
