IAT sensor location
Old 06-30-2008, 05:25 PM
ddogg69's Avatar
Default IAT sensor location
I would like to know where the iat sensor is located. I think it is a maf/iat sensor all in one but im not sure. If that is the case then it is the one in the side of the intake tube correct? I am looking for the iat signal and power wires. Any help would be greatly appreciated.
Old 06-30-2008, 09:49 PM
ohlord's Avatar
Banned
Default RE: IAT sensor location
Why are you looking for them?
ohlord
Old 06-30-2008, 09:55 PM
ddogg69's Avatar
I was going to install a performance chip to see if it actually did anything. Checked trap times before any mods now want to check them after install. Just want to make sure i use the right wires.
Old 06-30-2008, 10:04 PM
ohlord's Avatar
Banned
What model ,what engine?
Newer w210 is in with the maf.
want to prove what a mod did to power?
invest in
http://store.summitracing.com/egnsea...9&D=311339
best thing you can do for your quest for speed.
No chip 1999 E320 wagon running mid 13's
ohlord
Old 06-30-2008, 10:06 PM
ddogg69's Avatar
It is a 1998 e320 with the 3.2 liter. I am pretty sure it is in with the maf. Im just not sure what wire is the signal wire.
Old 07-01-2008, 12:01 AM
snanceki's Avatar
The MAF carries a thermistor which is used by the ECU to correct for Air Inlet Temperature.(AIT?)
IAT? Interior Air Temperature? is sensed by another sensor(s) within the cabin.
Sorry offhand I can't give you the pin-outs but I'm reasonably sure that if you Google "Bosch Mass Air Flow meter" you will find the pin out configuration you require.
Easiest way to check oerformance is with an appropriate OBDII scanner. try http://www.auterraweb.com/dyforwi.html
Stuart.
Old 07-01-2008, 04:44 PM
ddogg69's Avatar
I tried to google it but couldn't find any results.
mastermayhm069
01-29-2009 01:45 PM
Power Man
01-24-2007 08:33 AM
Power Man
01-23-2007 01:13 PM
jmang09
08-31-2006 02:00 PM
s420sanjose
12-10-2004 12:48 PM
Quick Reply: IAT sensor location
