How to reset service "F" on 2006 E350
door closed..key in position 1.. cluster display on outside temp or milage...then press the button on the cluster 3 times quickly... then you should see a voltage display....press the down arrrow to service or confirm....the plus and minus buttons is how you move up and down.then then press the down page button to confirm...thats the OK button if it doesnt work then try again untill you undersstand the menu and how to navigate it.. dont messs with the other setting tho..very important. its ahrd to tell you without actaually doing it. i do it all the time and dont really think of it.
ok Buddy....... So in summary
Position 0 – Locked Wheel – Engine Off
Position 1 – Wheel Unlocked – Engine Off
Position 2 - Wheel Unlocked – Engine On – This is where you normally have the key when driving
Position 3 – Wheel Unlocked – Starter Engaged
door closed
key in position 1................cluster display on outside temp or mileage
then press the reset button on the cluster 3 times quickly... then you should see a voltage display
press the down arrrow to service or confirm.... (not the PLUS or MINUS BUTTON
Did I miss anythign..... Thanks in advance
door closed
#9
yes after the voltage is displayed when you press the left side down arrow it will bring up the confirmation screen.. then use the right side minus buttons to move down to CONFIRM...then presss the down page button or the bottom page button thats closest to the center of the steering wheel. then it will say CONFIRM service ? then press the down page again... postion 0 is just putting the key in the igniton without turning it. postion 1 is turning it to the first CLICK... postion 2 is all dash lights on engine STILL off.
