help 95 e320 srs light,water liight,engine light on but all fine
Old 11-26-2006, 02:17 PM
95ee320's Avatar
Default help 95 e320 srs light,water liight,engine light on but all fine
i have a 95 e320 and my lights keep coming on the dash. first the srs light came on then a minute later the low antifreeze and now check engine light.my antifreeze level is fine and the car runs great still does anybody have any idea whats wrong.
Old 11-26-2006, 06:25 PM
Default RE: help 95 e320 srs light,water liight,engine light on but all fine
Youd coolant level sensor may be faulty, you need to pull the codes for the CELight, and, if I'm not mistaken, the dealer needs to reset the SRS light.
Old 11-26-2006, 07:24 PM
95ee320's Avatar
is it obd1? i have a obd1 scanner. where is the computer located at to pull the codes? by the battery?
Old 11-27-2006, 03:15 AM
snanceki's Avatar
First problem. Is your scanner connector the correct type.
I don't think your vehicle uses the standard OBD 16 pin trapezoidal plug.
Stuart
Old 11-27-2006, 05:14 AM
if it's a california benz then it will have the 16pin data link connector near the battery.
cbrook
10-20-2023 08:06 PM
whitey1979
11-29-2013 08:57 PM
shanless
12-21-2009 07:35 AM
nbrock_85
01-16-2009 04:16 AM
Dehaven
04-22-2004 02:02 AM
Quick Reply: help 95 e320 srs light,water liight,engine light on but all fine
