Possible Fix for 210 E320 a/c problems
Old Sep 3, 2007 | 01:44 PM
forearms's Avatar
Default Possible Fix for 210 E320 a/c problems
I had many issues with my 96 E320 210 with the air cond not blowing cold, left side blowing warmer, and when at idle blowing hot. I had replaced the comp, Drier, Drier lines, & expansion valve. I did a pressure test on the evap, flap test and N22 test, cleared codes, NO HELP! I was in front of the radiator with a cigarette in my mouth when the aux fans kicked in - the ashes blew out at me! The aux fans were runing backwards.I jumped out the plug pins from the aux battery tap and they ran in the correct direction. I then took apart the car harnnes plug at the aux fan connection (very simple, just be careful) and reversed the pins. The fansare now operating correctly and the a/c is much colder all the time especially when sitting and idle. Just an FYI for owners with similar problem. Chris.
Dws.
Jul 29, 2010 08:49 PM
shmooo
Jun 9, 2009 12:41 AM
Ali E300TD
Apr 1, 2008 07:17 AM
xtrmerik
Jun 16, 2006 08:32 PM
SOMEBODYTOO
Nov 1, 2005 07:13 PM
