Fan Clutch Bearing Bracket
Old 12-08-2003, 05:09 PM
Brody's Avatar
Default Fan Clutch Bearing Bracket
At 307,000 miles on the odometer my Fan Clutch Bearing Bracket on my 1989 300E decides to give up. Any tips on changing out that critter?
Old 12-08-2003, 05:58 PM
GermanStar's Avatar
Very common part -- while you're in there take a good look at the fan clutch, water pump and belt tensioner, as those are equally popular.
Old 12-10-2003, 11:57 AM
Go to this sitehttp://www.buymbparts.com/ for the best price on the parts you need and if you call ask for Rusty. He can get you anything you need for your benz.
Old 01-28-2004, 08:55 PM
fan bracket cost about $125. U need a X allen key put in center of the fan remove the fan. Then loose up the srew to remove the belt, there are 3,</P>
1)one access by the front,near the servo power steering liquid can, </P>
2)he other is right from the top where to adjust the timing. </P>
3) the sock absorber</P>
Then with the X allen key remove the bracket (4 screws).The change is simple but hard to put back the belt !</P>
I found that u need to change the wheel on the bracket to avoid squeek.</P>
Just did on mine.</P>
up2me
02-02-2015 07:37 PM
BlackE420
06-11-2006 06:46 PM
silversurfer
08-06-2005 12:56 PM
sleepdoc38
06-16-2005 07:05 PM
aharley1
01-15-2005 02:15 PM
Quick Reply: Fan Clutch Bearing Bracket
