1999 E300TD - smell diesel fuel
Old 08-17-2004, 12:41 AM
olynn's Avatar
Default 1999 E300TD - smell diesel fuel
I own a 1999 E300 Turbodiesel. I checked under the engine, and I don't see any puddles, but there's definitely the faint smell of unburned diesel in the air, after you shut it off. Is this normal? The fuel economy seems to be OK - I get 32 MPG on the highway, and something less than that in stop and go traffic.
Anyone have any suggestions as to what might be the cause, and what hints to give the service department people?
Old 08-19-2004, 08:43 PM
Default RE: 1999 E300TD - smell diesel fuel
Open the hood and look around the fuel injection pump, fuel injectors, fuel filters, for any wetness.
You could have a cracked fuel injection line as this is a common problem for diesels although you would have a drop in power if this is the case.
No, it is not normal to smell raw diesel fuel at any time!
Old 08-19-2004, 10:01 PM
how about the return line little hoses?check that too......
Old 08-20-2004, 01:26 AM
sleepwalker's Avatar
the vapor from the tank will have to pass the carbon canister before being disposed to the open air.
if this canister is broken, you will smell the strong odor of diesel. check the vent valve too.
Old 08-20-2004, 09:26 PM
olynn's Avatar
I only smell diesel when the engine is running. I also can see some drops of diesel fuel on the ground after I park it. It isn't much diesel that's leaking, only a little bit, but it is definitely leaking diesel. I've got a 10am appt at the nearest dealer to have them look at it.
Old 08-20-2004, 09:30 PM
olynn's Avatar
Unfortunately, I don't know what those would look like
I can see some small drops of diesel fuel on the ground when I park it. Power seems to be OK, but fuel economy in stop and go traffic is terrible - I averaged 17 MPG, which I know is way too low.
Old 08-20-2004, 11:07 PM
the leak must be coming from the return line right on top of the injectors. best way is to lift the car up and see.
look at the fuel filter too and lines.
Old 08-24-2004, 03:43 PM
olynn's Avatar
They said they had to replace some fuel line hoses - I pick it up today, and give them this go-kart loaner I've been driving back
  #9
Old 10-31-2004, 05:21 PM
I've had the return lines replaced on my 95 300 D recently, and that took care of the diesel smell. Over time, the corrosiveness of the diesel fuel damages the gaskets, and return lines. The parts are not expensive, though the labor may run higher...
phusky
04-28-2010 05:20 AM
curtis73
09-03-2008 12:53 PM
graysilm
05-07-2008 02:49 PM
spike1932
01-26-2005 12:54 PM
dave9998
11-08-2004 11:39 PM
Quick Reply: 1999 E300TD - smell diesel fuel
