E200 alarm/immobiliser probs
Hi guys,
I have a '96 E200 (non-komprssor model).
I was using the car as normal, went to work no issues, when i came out at lunchtime, my key fob would not work, so i pressed the button really hard and the locks/doors opened.
i have the flip-out key
when i switched off the car and closed the door and pressed the key fob, the doors wouldnt close, infact the key fob didnt seem to be doing anything!
called the roadside recovery guys and they couldnt figure out what the problem was.
could anyone help guys?
much appreciated
[IMG]local://upfiles/10897/B0347D625D5F46CBAB8C3BB4BA40FF4C.jpg[/IMG]
much appreciated
RE: E200 alarm/immobiliser probs
what do the leds on mirror do when you lock unlock if they flash together then key batteries need renewal. if not do you have spare key? you can also attempt to recode key by pointing at mirror for 10 seconds then putting ignition in position 2 repeat until green led in mirror flashes hope this helps u
ORIGINAL: mawls
i dont have a spare key im afraid.
what do you think???? how do you recode the key, will this work??
cheers
