Does any one kno wat I need to do to lower my e320 w210?
Well guys I want to lower my ride (97 e320) and i wanted to kno wat do I need to do so? just springs would do the trick, will i need dampers and all that stuff?
thanks guys!
thanks guys!
the real answer is this: what you need depends on what you desire in your drop. if you
install sport springs with 1.5"< drop, then you'll also need shorter/sport shocks $400, as
well as realignment, $150; and very likely camber adjust kit for the rear $300.
to the suggestion that you only need lowering spring....that is overly simplistic and mis-
leading.
leading.
laser_doc
11-04-2008 05:39 PM
frk203
10-20-2008 10:03 AM
xjvoorheesx
07-29-2006 01:21 PM
