95 E320 Brake Noise
Old 03-24-2008, 03:24 PM
golfinator's Avatar
Default 95 E320 Brake Noise
Hello from Atlanta! Particularly inhot weather, the brakes seem to be barely touching the rotors and making noise. When you touch the pedal, the noise stops. Also, when backing down a steep driveway, occassionally there's a pop noise andI can feel it in the pedal. These symptoms reappeared shortly afterrotors, front calipersand padswere replaced and thelines bled. The car stops ok, but has a scrungy sound at the end of stopping.Any suggestions would be appreciated.
Old 03-24-2008, 04:51 PM
ohlord's Avatar
Banned
Default RE: 95 E320 Brake Noise
Have you checked the e brake adjustment>Did you use anti sqeek on the pad backings when the brales were done?
ohlord
Old 03-24-2008, 04:56 PM
Hey.....My brakes (95 E320) aremaking the same "scrungy" sound as it comes to a dead stop. Kind of a grindy sound.
Pads are near new (OEM) and I had the rotors surfaced.
Still.............hmmmm.
What to do?
Old 03-24-2008, 05:56 PM
golfinator's Avatar
Thanks ohlord. I followed the Bentley Bible and only used heat resistant paste on the 2 edges, no anti squeek on the pad backs. Haven't checked the e brake, but am99% sure the noise is on the front brakes.
Old 03-29-2008, 07:58 AM
Scuddog's Avatar
Imitation rotors and pads make that sound. I know that from experience... $$$$$$$$$ Good luck! [&:]
pointroad
06-29-2012 07:35 PM
fly_major_fly
10-30-2005 01:28 AM
newkid
12-13-2004 12:04 AM
jonathanw
07-26-2004 04:28 PM
Quick Reply: 95 E320 Brake Noise
