BLOWER MOTOR/FUSE LOCATION 97 E420??? HELP??
Anyone know which fuse is for the blower motor on the 97 E420?? Dealer TOLD me the blower motor is LOCATED in the DASH(where???) AND the fuse is on the motor itself??? Climate control Display works fine, but has no backlights at night AND of course no BLOWER!!! PLEASE HELP!!!!
RE: BLOWER MOTOR/FUSE LOCATION 97 E420??? HELP??
for starters there is no fuse for the blower motor. second it is located under the passengers side under dash panel there are 3 Phillips screw under there holding up the black panel remove the screws then there are like 8 torx t20 screw holding in the cover. remove them and there is you blower motor be sure you have a blower speed regulator in hand before you take it apart more than likely that is your problem.
