P0455 error code (Please Help)
Old 09-05-2007, 01:51 PM
blackstarr777's Avatar
Default P0455 error code (Please Help)
I have a E420 and recently my gas light started flashing and then my engine electronics ligh came on. I called the dealer and explained the problems and they stated to change the gas cap. I followed those directions and it went away. Long and behold it came right back so I went to my MB specialists and did a scan and i received an error code P0455 something to do with the emissions. He reset the code and it came back after a couple of weeks so can someone tell me if they had this problem beforeand what didyou do tofix it.
Old 09-05-2007, 03:11 PM
snanceki's Avatar
Default RE: P0455 error code (Please Help)
P0455 Evap Emmissions systems (big) leak.
Sure your gas cap is OK and seats properly?
If not a tube has likely come off somewhere between the tank and the charcoal cannister usually located near the tank or in the engine compartment.
Stuart
Old 09-06-2007, 01:05 PM
Is it possible you can direct me to find this hose thats near fuel tank and the engine compartment.
Old 09-06-2007, 03:24 PM
ohlord's Avatar
Banned
http://w210.pietrzyk.net/enginesm112_47fuelsys.htm
hope it helps
ohlord
Old 09-07-2007, 05:09 AM
snanceki's Avatar
Nice one OhLord.
So its a pressure sensor located in the tank that is signalling the problem.
Stuart
Old 09-07-2007, 12:17 PM
ohlord's Avatar
Banned
Probably the purge valve in the engine compt.,after that test,onto deeper measures.
see my post on mbworld.org w210 section,I detailed the test and location.
ohlord
Hello England!
jajjrr12
04-09-2012 09:54 PM
fastedy1
12-16-2011 07:39 AM
jscott8886
11-12-2011 03:51 PM
01Benzys430
05-05-2009 10:00 PM
1stmb
11-02-2004 10:12 PM
Quick Reply: P0455 error code (Please Help)
