89 300E radio removal? - Mercedes Forum - Mercedes Benz Enthusiast Forums
Thread Tools Search this Thread
Old 06-05-2006, 02:35 PM
Default 89 300E radio removal?
Can you direct me to a post or let me know how to pull out this factory radio.
Also, I beleive this unit is causing a battery drain. The radio shuts off but still makes noise when car and radio are turned off?? Does this radio need to be serviced and can it be repaired or should I get an aftermarket radio?
Old 06-05-2006, 09:19 PM
Default RE: 89 300E radio removal?
you need to remove the wood trim underneath and on top of the radio to give you room to take out the radio.
Old 06-05-2006, 10:53 PM
Old 06-06-2006, 11:44 AM
Thanks Jackd!
Have you heard of the radio causing a battery drain while off. This radio actually makes noise while the car and radio are turned off.
Old 07-24-2006, 05:27 AM
HI EVERY ONE
don,t you have to inter a code after you install the radio on the car .
i just bought 300e 1989 and i,m afraid to remove the radio or disconnect the battery for this reasone
Old 07-25-2006, 04:32 AM
you have the code in your owners manual leather case.
Old 07-25-2006, 01:14 PM
hi
ijust bought the car and i do not see any code for the radio on my owner manual leather case is it a card .
Old 07-26-2006, 12:05 AM
I have it printed on mine, on the anti-theft card for the radio.
  #9
Old 07-26-2006, 09:50 PM
hi battlecat714 thank you for all the help.
ican not find it any where i also contact the old owner and she said she does not remember any thing about code , should i call the dealer for the code or it is some where i can get the code from .
thank you in advance
  #10
Old 07-26-2006, 10:58 PM
you can call or go in person to the dealer, give them the VIN# and they should help you...or ask around here on the boards, need serial number and model of stereo...
Thread Thread Starter Forum Replies Last Post
87 300e headgasket removal & instalation sfbaytech General Tech 1 01-10-2016 07:30 PM
wiper removal, 300E jager General Tech 0 09-24-2007 06:23 PM
dashboard removal (speedometer removal) 1986 190D jenwseto General Tech 1 07-10-2005 08:50 PM
300e Rocker arm removal wcpease General Tech 1 05-10-2005 09:01 PM
89 300E Console removal wertjamp Mercedes E Class 6 08-13-2004 04:41 PM
Tags
1992, 300, 300d, 300e, 89, benz, code, install, installation, installing, mercedes, radio, removal, remove, se, stereo
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
