2004 E320 No Interior Heat - Mercedes Forum - Mercedes Benz Enthusiast Forums
Thread Tools Search this Thread
Old 05-06-2008, 05:35 PM
Default 2004 E320 No Interior Heat
I know it's spring but the heater seems to have stopped working, no matter what tempI set the controls on, 72 degrees to max still no heat (both sides). I encountered this problem about 4 months ago but it only occurred for about 3 hours. This problem has lingered for a week and counting.
I've read another post some time back describing this same problem i believe and they said it was an actuator or valve near the heater core...it was somewherein the windshield wiper bay area.
Question, how doI determine what the problem is? and if it's the actuator (valve) whatever you call it, what's the part number.
thanks for any info...nothing worse than a beautiful car and no heat.
Frustrated
Old 05-06-2008, 06:14 PM
chassis221's Avatar
Default RE: 2004 E320 No Interior Heat
yes it is that valve under the wiper. heat switch over valve
Old 05-06-2008, 09:30 PM
Banned
What is your engine temp 80-90c?
have you checked the coolant level?
run the diagnostics
http://www.eclassbenz.com/node/27
post the values 1-8 and the errors.
fuse or relay or changeover valve(there was a tech service bulletin so dealer may have a recall on the valve*call and ask could be bad ,but I dont have a fuse list for your year.
part #A2118320584 valve
ohlord
Thread Thread Starter Forum Replies Last Post
Interior parts (sunvisor-interior light-clothes hook etc) lentomies Mercedes M Class 1 10-30-2012 12:33 PM
2004 ML350 with no Heat Jr Persaud Mercedes M Class 0 12-04-2011 06:40 PM
98 E320 engine heat the_unlord Mercedes E Class 8 05-09-2007 10:57 AM
95 E320 Heat Gauge qghauri Mercedes E Class 5 11-28-2005 01:14 AM
HEAT AND NO HEAT raspro7 Mercedes C Class 0 01-31-2005 01:14 PM
Tags
2004, 320, a2118320584, changeover, class, e320, heat, heater, location, mecedez, mercedes, mercedez, part, problems, switchover, valve
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
