changing 03 E320 plugs
Old 05-05-2010, 10:27 AM
badboy911m's Avatar
Default changing 03 E320 plugs
Hi , i tried finding where the plugs are located on the car but cant find them. can someone tell me where they are located and if there is a special way of changing them...thanks
Old 05-05-2010, 01:03 PM
nevilleuk's Avatar
in the centre like all other cars follow ingnition leads
Old 05-07-2010, 08:31 PM
specauto's Avatar
Default Plug Location
Not a stupid question if you've never had one of these cars. Remove the two nuts holding the air intake, loosen the hose clamps and pull the air intake tube to the side. There are socket head cap screws that hold the spark plug/coil pak cover on, take those off and pull off the top cover. Plugs are resistor type. This is one operation you can do with limited skills or tools.
Old 05-09-2010, 09:22 PM
mike278's Avatar
Remove the air cleaner housing so you can get to things. You will see three coil packs on each valve cover. The ignition leads will go to the plugs. Get a pair of spark plug boot pullers. This will save a lot of cursing, but there will still be plenty involved. Use a torx driver to remove the coilpacks and wires. You can lay them on the engine without unplugging them or you can just take them off, your choice. Next you will need a swiveling (universal) spark plug socket. Matco makes a great set that isn't ridiculously expensive. A flexible magnet will help you get them out. Be sure to use anti-sieze when you put them back in.
Old 05-25-2010, 03:20 PM
lalovelyloquita's Avatar
Default plugs
mike your awesome! I like to try things myself first! $$$ is tight right now
sal911
06-23-2018 03:26 PM
ADS01
01-04-2007 10:16 AM
spudbeep
05-17-2006 08:38 PM
jdhicrop
10-24-2004 05:13 AM
joepaisley
05-24-2004 11:42 PM
Quick Reply: changing 03 E320 plugs
