Mercedes CLS Class CLS500 Coupe.
Cls 350
Old 02-16-2012, 08:12 AM
carney's Avatar
Question Cls 350
I have the CLS 350 09 registration and wanted to know if:
a) The outside temperature gauge can be changed from celsius to farenheit
b) The inside heater is 2 dials and I wanted to know if there is a way of showing this in either LED on the screen or through the menu features
all help will be appreciated
Old 02-16-2012, 05:11 PM
chassis221's Avatar
yes celcius to farenheit should be able to be set in the instument cluster under "settings"
not sure what you mean on the other question
Old 02-17-2012, 02:20 PM
carney's Avatar
Default Cls 350
Thanks for that information, I will give it a try on "settings" as you suggest, I have heard it mentioned that because the Mercedes are made in Germany they have "stuck " with celcius, previously had a BMW and had no problem with C to F.
To explain the other question in more detail would be that on some models the temperature shows up in the screen which shows the minimum to maximum bars which are lines inthe shape of a fan, in a nutshell it would help if when I set "say" the gauge on 24c something on the screen would say 24c and as the inside temperature dropped in the car so the reading would also drop, maybe asking for to much, your comments would be helpful
carney
05-07-2012 03:22 PM
hockbeng.lim
05-07-2011 06:23 AM
kallepsko
07-30-2008 04:50 AM
Darko_CLS350_SLK55
06-30-2008 12:23 AM
Darko_CLS350_SLK55
06-29-2008 01:48 PM
Quick Reply: Cls 350
