problem with comand ntg 2.5 with HDD
problem with comand NTG 2.5
Hello I have the solution to your problem with comand NTG 2.5 A-class W169.
-weak radio reception
- weak bluetooth reception
- no audio out with handsfree telephone system
Please email me
etnico.etnica@libero.it
Please email me
comand aps
HALLO. AS FAR AS I KNOW, B AND A CLASS HAVE THE SAME "PROBLEMS" WITH COMAND NTG 2.5 HDD.
OLDER COMAND USED THE SAME QUADLOCK AS APS 50. NEW COMAND 2.5 HAS SOME DIFFERENCES. FOR EXAMPLE YOU NEED A ANTENNA RADIO ADAPTER AND ALSO YOU NEED TO INSTALL THE MICROPHONES DIRECTLY ON THE COMAND 2.5, SINCE THIS UNIT HAS INSTALLED A BLUETOOTH DEVICE.
I BOUGHT THE ANTENNA ADAPTER FROM FRANK. SEE : http://www.kabeldaviko.de/fakra_doppelfakra.html
THIS COSTS I THINK 11 EURO. THE SAME SELLER GAVE ME ALSO THE MIC CABLE READY TO BE INSTALLED: http://www.kabeldaviko.de/mikrofonleitung.html
BECAUSE COMAND 2.5 NEED AN EXTRA POWER FOR THE ANTENNA RADIO, YOU JUST HAVE TO UNPLUG THE WIRE FROM SONTACT 13 ON THE QUADLOCK AND PUT IT DIRECTLY ON THE CONTACT NR 7 ON THE MICROPHONE PLUG (WHITE PLUG). DO NOT WORRY THIE IS VERY VERY EASY.
YOU CAN ASK FRANK TO SEND YOU THE DIAGRAM PER EMAIL. HE IS VERY VERY HELPFUL AND ALSO SPEAKS ENGLISH. YOU CAN ASK HIT ANYTHONG YOU WANT ABOUT NTG 2.5. HE IS AN EXPERT.
I HAD A VERY BIG PROBLEM AS NO MERCEDES DEALER COULD HELP ME. FINALLY, I BOUGHT THE TWO CABLES FROM FRANK, FOR TOTAL 25 EUROS AND I VISITED A MERCEDES DEALER. I TOLD THEM WHAT TO DO!!!! AND IN 1 HOUR THE PROBLEM WAS SOLVED. EVERYTHING NOW WORKS OK.
IF YOU WANT MORE INFORMATION SEND ME YOUR EMAIL AND I CAN SEND YOU THE DIAGRAM. MY EMAIL IS: ath.tsirikas@gmail.com
I HOPE I HAVE HELPED.
REGARDS
THANOS
REGARDS
THANOS
Diagrams?
Hello, I´ve read your pos, can you send me the diagrams to install ntg 2.5 on my W245 car with comand APS DVD installed?
For the antnna, I need also the two wire or one wire connector from kabeldaviko?
Thank you
Thank you
REGARDS
THANOS
REGARDS
THANOS
