Mercedes CL Class Mercedes CL500 and Mercedes CL600 Coupes.
Seat Control Module Drains Battery - Need Advice
Old 01-25-2009, 01:43 PM
dzvanas1's Avatar
Question Seat Control Module Drains Battery - Need Advice
NOTE: First take a look at this: http://www.benzworld.org/forums/w203...ower-seat.html
Hey, my seat control model also drains my car battery..
My car is Mercedes CL500 W215, it has a different seat control model connector and only has one 12v wire and one ground, i was wondering if this method would work on my model. Heres a few diagrams:
Connectors: http://img132.imageshack.us/img132/6...nectorstd3.png
Seat Control Model Connector: http://img140.imageshack.us/img140/3884/1000352oq9.jpg
1-20: http://img132.imageshack.us/img132/5931/120cp3.png
23-43: http://img132.imageshack.us/img132/3808/2343db2.png
44-65: http://img201.imageshack.us/img201/5091/4465xw5.png
Connetor Pins: http://img513.imageshack.us/img513/5...orspinsqy5.png
If i cut the 13.20 cable and connect it to the 13.14 cable will the seats work when the key ignition is active? Wouldn't it harm anything? (burn cables / blow fuses etc)
Any ideas how to make the seats only work when the key is in pos. 1? Thanks!
Old 01-25-2009, 06:37 PM
1sloturtle's Avatar
why messwith factory wiring and by pass relays that is very dangerous and i've see them catch fire quickly see the post i made to the 203 with seats inop . the amp draw test will determin which module is at fault. in your case if you know best to buy the module rather than bypass the relays internal in the module ( the short causingthe amp draw is internal in the module causing the batt. to drain. ) bypassing doesnot do anything you will still have excessive draw on the system
frankthetank
01-29-2011 06:12 PM
Papatatun
03-15-2009 12:20 PM
Papatatun
03-15-2009 08:48 AM
AirBoss
09-25-2008 10:14 AM
gmen0101
10-23-2006 06:15 PM
Quick Reply: Seat Control Module Drains Battery - Need Advice
