Mercedes CL Class Mercedes CL500 and Mercedes CL600 Coupes.
Left Wheel Leakage CL500
Old 12-06-2010, 08:59 PM
YoungsCL's Avatar
Default Left Wheel Leakage CL500
My ACTIVE BODY CONTROL warning is coming on/off periodically when i would stop the car switch off start again it would clear itself in the last couple of days a new warning has appeared in red text ACTIVE BODY CONTROL drive carefully !& the ride is very soft. It's off in the morning but will at least come on once a day. I have checked the fluid and notice leakage all on my left front tire with hydraulic fluid. The reservoir was down about 1/4 of a inch also the top of the reservoir is wet and some spray on the left side of the engine. My mechanic changed the filter but it has happen again. Has the pump gone bad or hose?.....all replies greatly appreciated
New member...great forum.
Old 12-09-2010, 08:50 AM
chaseturbo's Avatar
I had the same issue on my CL55..it was a fitting on the front left. Had the fitting replaced and fixed the issue..about 200.00..
Good LucK
Old 12-15-2010, 02:52 AM
TireCrawlerNikki's Avatar
take the vehical back to your mechanic or dealer.
faeriegrove
09-03-2013 01:29 PM
FreshC230
09-11-2008 06:49 PM
FreshC230
09-11-2008 04:56 PM
kirstywirsty
03-05-2007 07:35 PM
stifland
05-01-2004 05:19 PM
Quick Reply: Left Wheel Leakage CL500
