Mercedes CL Class Mercedes CL500 and Mercedes CL600 Coupes.
Crankshaft sensor failed causing engine to cut out
Old 01-16-2016, 01:45 PM
Alan Thompson's Avatar
Default Crankshaft sensor failed causing engine to cut out
Has anyone experienced their engine cutting out with loss of power to the power steering and reduction in assistance to brakes
Old 05-17-2018, 02:56 AM
Zaid Alobaidi's Avatar
Before 3 months I parked my car came back after shopping and trying to start the car surprise me took so long to start after going back home left car for 2 ours and then came back again car not even start anymore also check engine came ON pulled obd2 code and it gave me faulty Crank shift sensor Order one Boosch from Amazon and car back working fine I don’t know what do you mean by brakes and loses power Is that after replacement or Before that ?
Old 05-17-2018, 01:08 PM
It sounds like the engine going into limp mode from what the OP is describing. This is a fail-safe mode that your car goes into to prevent other components from getting damaged.
JA560
09-16-2010 10:03 PM
gpharper
04-23-2009 02:53 AM
Airwrek1
02-14-2009 11:24 AM
Skrimp
02-15-2006 03:21 AM
c280estateguy
10-21-2003 09:44 AM
Quick Reply: Crankshaft sensor failed causing engine to cut out
