Mercedes CL Class Mercedes CL500 and Mercedes CL600 Coupes.
CL500 ABC Fault
Old 08-02-2009, 05:01 AM
g4efx's Avatar
Default CL500 ABC Fault
Hi hope you can help.
cl500 2001 ABC fault, all started when the car was left for 1 month without being started the battery went flat, no problem prior to this event.
ABC white light "visit workshop" this has been appearing for sometime after the flat battery but would disappear.
Car holds level and height overnight.
The red ABC warning has started appearing this last few days the suspension gets bouncy and raise lower switch inoperative.
stored codes:
CAN bus N47-5 interfered
n15/3 CAN bus interfered
terminal 30 low stored voltage
critical fl car stored -0001 height
system pressure stored too low code 006
component B22/6 rr journey sensor malfunction
A67r1 potentiometer vertical position short or open
A67r2 potentiometer horizontal position short or open
B1000 module fault.
Tony
g4efx
08-02-2009 02:16 AM
benzthere
05-05-2009 06:40 AM
k edgar
05-30-2007 10:25 AM
Scott500
01-27-2006 02:34 AM
jud149
09-30-2005 06:30 PM
Quick Reply: CL500 ABC Fault
