Mercedes CL Class Mercedes CL500 and Mercedes CL600 Coupes.
Both front turning signal lights not working
Old 12-01-2008, 12:13 AM
theonerainbow's Avatar
Default Both front turning signal lights not working
Hi, Everyone.
About a week ago, my 2002 MB CL500 Sport Pkg have a couple of problems as follows;
[ol][*]Both side of front turning signal lights are not flash but the bulbs are fine. The instrument panel shows warning sign "Check Left Turning Signal Lights" and Right too, also the indicate red light flash quickly when I turn on the turning sign. Mirrors and rear sign and lights are flash normaly. Any higher advises please?[*]Front right side of body vibrating like I am on the massage chairwhen the car running around 68 mph ~ 90 mph on the freeway. I can feel its happening this side but its not a tire or wheel balances, I already check and make sure O.K a couple of times. Please help me.[/ol]
Thanks and have a good time everyone.
Old 12-01-2008, 08:06 AM
chassis221's Avatar
Default RE: Both front turning signal lights not working
first there is an update for your turnsignal wire harness... should have already been previously done since your car is a 2002. new sockets and harness for a new ground points. if you remove your front turnsignal sockets and there is a wire attached to it then its been updated if no wires are attached to your bulb sockets then you need to have them installed.
Old 12-01-2008, 12:37 PM
Hi. Thanks a lot for your advises!!!
I have checked both sockets but there's no wire, just bulb sockets. Do I have to install new bulb sockets with bulbs? Please advise me. Thanks again! Have a nice day.
Kim
patricknif
03-04-2012 06:38 AM
ab4jy
11-19-2010 12:29 PM
Louis Lam
07-23-2009 03:16 PM
lighting
11-30-2008 01:23 PM
slick1
07-30-2007 07:05 PM
Quick Reply: Both front turning signal lights not working
