Fuel pump relay and fuse location
Old 08-06-2009, 07:45 PM
lighting777's Avatar
Default Fuel pump relay and fuse location
I own a 2002 C240 and yesterday fail to start. I've narrowed down to lack of fuel(disconnected the line from the rail and crank it) and nothing came out, checked all fuses and removed the rear seat and check for current in the wiring leading to the pump with the swicht on and nothing, then I spray some fuel inside the throtle body and start right up and runs until the sprayed fuel runs out. If some body could tell me were the relay is at or perhaps the fuse or how to solve this issue I'll be forever in debt. Thanks............
Old 08-06-2009, 07:51 PM
Sorry, I forget to mention that I've also check the fuses in the trunk and they're all good. thanks..........
Old 06-10-2011, 07:50 PM
inkpusher's Avatar
Did you get an answer? I have the same problem on a 2003 C240. Thanks.
Old 06-10-2011, 08:13 PM
chassis221's Avatar
common problem is the fuel senders under the back seat
Old 06-11-2011, 05:24 AM
inkpusher's Avatar
Default New Pump Installed
I installed a new fuel pump but, but no change. The car cranks but doesn't start. I'm not getting a lot of fuel at the fuel rail nipple.
Old 06-11-2011, 06:52 PM
inkpusher's Avatar
Default Found the problem
The failing pump that was replaced had burned the ground wire running to the sending unit. The ground was repaired and the problem has been resolved.
Old 06-11-2011, 11:00 PM
chassis221's Avatar
great, thanks for posting the fix.
Old 10-30-2015, 04:32 AM
Ginodeabreu's Avatar
Default Confused
I have 02 c320 and would simply like to know the location of the fuel pump relay.can someone please help. Thank-you
  #9
Old 11-14-2023, 07:13 AM
Jayjosh's Avatar
please what is the ground wire, I have replaced my fuel pump, I have replaced my fuel filter, I have also replaced my the fuel gauge on the other side(directly behind the driver seat)
but my car takes up to 6-7 cranks before the car would start, when I’m luck it cranks twice, very rarely do I get it start at first crank, please help, I’ve spent a lot on this
  #10
Old 12-13-2023, 06:15 AM
rottes's Avatar
It can be similar with the p0128 obd error code, please also check the o2 sensors.
starbo
01-31-2011 06:26 PM
hansnovel
11-23-2009 01:19 PM
hapaschold
10-05-2007 05:59 PM
petroff
05-03-2007 09:05 PM
BenzoDJ
03-30-2007 08:01 PM
Quick Reply: Fuel pump relay and fuse location
