CPS location on 94 c220
Old 06-24-2008, 04:58 PM
bene36m3's Avatar
Default CPS location on 94 c220
Does anyone know the location of the crank position sensor on a 94 c220. Im familiar with BMWs, and have rarley worked on a merc. Thanks for your help.
Old 06-25-2008, 05:00 AM
Default RE: CPS location on 94 c220
Hi
I think you will find it on the left hand side (looking forward) of the engine casing, near where it meets the clutch casing, at around the 10 o'clock position. Access from top of engine. The wiring plug should remove easily by squeezing its smaller sides. There should be one Torx headed bolt to remove, after which a screwdriver can be placed between the sensorcasing and its recess in the engine casing. Twisting the screw driver should be enough to spin the sensor slightly loosening it before pulling it to remove, pre-soaking carefully withWD40 or similar if required.
Old 06-25-2008, 08:58 AM
bene36m3's Avatar
Alright, thanks a lot. Im going to try it out.
Frank Stephenson
11-16-2014 04:09 PM
kupiec79
10-28-2009 09:26 PM
hjk
08-10-2007 06:06 PM
Longhaily
07-11-2007 06:04 PM
stepmom89
05-26-2006 08:02 AM
Quick Reply: CPS location on 94 c220
