New Brake Pads and Rotor with Noise - Mercedes Forum - Mercedes Benz Enthusiast Forums
Thread Tools Search this Thread
Old 01-24-2009, 07:41 PM
Smile New Brake Pads and Rotor with Noise
I've 2003 c230 Komp with 70k miles.
I'd my mechanic replaced front pads and rotors with mercedes parts and it started to make some noises.
The noise sounds like low abrasive - ones come from worn out pads.
This only happens at 40-50mph and semi-hard braking.
The mechanic took out the both pads out and they can't figure out where the noise is coming from. The rear pads and rotors are fairly new.
I was wondering if there is a certain direction that the pads must be fitted or the pads are bad ones and must be replaced.
If anybody had similar problem, let me know it would save me a lot of time going back to the mechanic who can not figure out where the noise is coming from.
Old 01-26-2009, 08:54 AM
fnc fnc is offline
The finish of the rotor can cause a rotational noise if it not treated properly. Also if a coating is placed on the rotors during manufacturing and they do not remove it before install you can get some noises. If that is the case the coating can become embedded into the pad and remain noisy until they were a bit.
Old 01-26-2009, 06:08 PM
Thanks fnc for your info. We had our from brakes pads replaced by dealer at 30k miles and we never had this problem at that time.
But there is no noise when there is slow braking. The noise only develops when there is semi-hard braking on or about 40-50 mph. It sounds like a low abrasive noise. There is no sharp or high pitch grinding noise like when your brakes wear off.
My mechanics have taken the brakes apart and they've used sand paper to make the pads smoother. After this procedure, brakes have reduced the noise but still make annoying noise. Do they need to replace with a new sets of pads?
Old 01-27-2009, 06:43 AM
fnc fnc is offline
Sounds to me like the rotors are at fault. From what you are describing. They will make this type of noise if they have a rough surface. May look smooth to the eye, buy to touch you will feel what I am talking about.
Old 01-30-2009, 05:26 PM
My mechanic have replaced with new rotors and pads and the problem went away.
They said it was either problem with rotor or pads and they did not wanted to take a chance so they ended up replacing both parts.
Thread Thread Starter Forum Replies Last Post
Brake pad and Rotor georgedel46 Mercedes S Class 0 10-07-2009 02:43 PM
Brake Job for S500 year 2000-Best brake pads? gpicou Mercedes S Class 0 01-29-2009 09:40 AM
Front Brake pad/rotor and Battery questions rosario Mercedes C Class 1 01-22-2008 11:40 AM
Brake pads/rotor and warranty myfstmb Mercedes C Class 3 08-27-2006 10:19 PM
1999 E320 rear rotor and pads CRT Mercedes E Class 4 09-23-2005 06:18 PM
Tags
benz, brake, break, fnc, front, high, low, make, mercedes, noise, pad, pads, pitch, pitched, rotor, rotors
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
