mercedes 05 c230 oil in water - Mercedes Forum - Mercedes Benz Enthusiast Forums
Thread Tools Search this Thread
Old 11-09-2009, 12:21 PM
Default mercedes 05 c230 oil in water
recently I check the water in my tank reservoy and I notice that there was oil in the deposite so I went to the mecanic to check the compretions and they where the same in the 4 cy. The car has never overheated and has only 30,000 miles there are no misfires or temperature issues runs great I dont now if it probably that the head gasket went off with out overhating the car
Old 11-09-2009, 01:02 PM
ForcedInduction's Avatar
The headgasket is blown between the oil and cooling system. It doesn't always break into the cylinder.
Old 11-09-2009, 01:08 PM
is there anothere test I can do to check the head gasket
Old 12-09-2009, 08:49 AM
I think a compression check helps diagnose blown head gasket.
Old 12-12-2009, 07:54 AM
Only if the gasket is broken into the cylinder. A break between the coolant and oil systems will have no affect on cylinder operation.
However, coolant in the oil and vice versa are very harmful to the engine and need to be fixed immediately.
Old 12-17-2009, 01:12 PM
MBGT, what you can do is open up the radiator cap (cold) and put a radiator pressure tester in place of the radiator cap and crank the engine over, if it starts you can shut it off right away. Look at the pressure gauge and see if you get any readings. This will at least rule out head gasket leak from the cylinders.
What color is your coolant? Is it milky white? If not it could be that it's not oil as hot oil and hot coolant will blend and turn white. One test you can do here is add a dye (you can get this at most parts store) for oil and add it to your crankcase, run the engine for about 15 minutes and use a black light to see if you can see the dye in the radiator (make sure it is cool down enough to safely remove the cap, remove the cap slowly). Squeeze the upper radiator hose to make sure it's not hard as this would indicate high pressure (hot coolant).
Alan.
Thread Thread Starter Forum Replies Last Post
oil leak on cooling water side johnny cruz New Mercedes Benz Forum Members Area 0 11-23-2010 08:30 AM
Water In Oil - 4.5 - What Next? INTELLIGENT ADVICE PLS speakernut General Tech 4 12-08-2008 07:54 AM
WATER & OIL\ WHY??? oukno General Tech 5 08-10-2008 11:56 PM
SL 500 oil water mixture / parts fdo_hidalgo Mercedes SL Class 0 05-14-2007 01:36 PM
water water everywhere! ska Mercedes E Class 1 06-11-2005 11:15 PM
Tags
05, add, benz, c230, c240, cap, coming, coolant, forum, mbgt, mercedes, milky, oil, radiator, water
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
