C280 Wire harness
Old 09-28-2005, 10:48 AM
crit1's Avatar
Default C280 Wire harness
I need to replace the wire harness on my '95 C280. Is this something that can be done by an average DIY? How long would it take a competent MB mechanic? That way, I'll just double my time. Also, are the replacement wire harnesses of better quality and therefore should last longer than the original?
Old 09-28-2005, 11:41 AM
Default RE: C280 Wire harness
http://www.club202.com/forums/showth...t=wire+harness
thats a link to sum1 elses changing pics.
yes you should be able to do it yourself.
the new ones are fixed and mint and wont stuff out on you
and in exchange for this help you have to post up a pic of your car!
Old 09-28-2005, 12:40 PM
crit1's Avatar
Thanks a ton. Very helpful information. I just have to get over the fear of screwing something up big time on the car, before I try something like this. I'll work on getting a photo of the car on the site. It's just a stock '95 C280 (with dirty alloys right now).
Old 09-28-2005, 02:28 PM
C280 wizard's Avatar
IMHO THE ABOVE AVERAGE DIY COULD TACKLE A JOB LIKE THIS. DO YOU HAVE KNOWLEDGE OF 12 v SYSTEMS, A LOT IS PLUG IN, BUT IT IS NOT AS EASY AS THE C202 BOARD INDICATED. BUT THAT'S IS MY OPINION, A LOT OF PEOPLE WILL TRY TO FIX THINGS AND RUN INTO A GLICTCH THAT NO ONE ELSE MIGHT HAVE AND THEN THE PROBLEMS START.
Old 09-28-2005, 04:16 PM
crit1's Avatar
I don't have experience with 12v systems, but it can't be that hard if it's basically plugs. My fear is taking something off/apart that I don't know how to put back together. There's always the tow truck option to the mechanic!
Old 09-28-2005, 04:27 PM
When I start taking things apart on my car, I have my digital camera and take pcitures of the disassembly and refer back to them when I put it back together. But then there are some parts that are not meant to be "taken" and you have to buy a new one. So, if you think you can handle this job go ahea.
anacortesjim
10-17-2012 07:07 AM
shayne crowe
11-04-2010 10:51 PM
nickc280
06-04-2006 04:02 AM
shayne crowe
03-14-2005 01:04 PM
Quick Reply: C280 Wire harness
