ENGINE OIL C280
Old 03-29-2008, 07:56 AM
EVILWEELEE's Avatar
Default ENGINE OIL C280
HI GUYS, IM NEW TO MERCEDES GAME, IVE JUST PICKED UP A C280 1998. WHAT GRADE SYN ENGINE OIL SHOULD I USE?
Old 03-29-2008, 08:40 AM
mrcoyote's Avatar
Default RE: ENGINE OIL C280
For most people, a 5-30 or a 10-30 synthetic like Mobil 1 is fine. If you are a COSTCO member, they have
cases of 6 bottles going on sale soon at $8 off per case (limit two cases) and both weight oils. I think the sale
starts on Apr. 4 or thereabouts. Their regular price is around 30 bucks a case I think.
Old 03-29-2008, 05:39 PM
EVILWEELEE's Avatar
WELL HERES HOW IT WENT W/ THE OIL. I CALLED THE DEALER AND WAS TOLD TO USE THE 0-40W, SO I DID THAT AND MAN THERE PROUD OF THAT OIL. YOU GUYS JUST USE THE 5-30W AND STILL GET 8-10,000 MILES OUT OF IT?
Old 03-31-2008, 02:03 AM
mrcoyote's Avatar
Unless you are living in the North Pole, a zero weight oil isn't really necessary, but........yes, a lot of people use it.
It's very thin at startup, so in cold weather it makes it easier for the engine to turn over. The weight of the oil has
nothing to do with the oil change interval. Apples and oranges. By and large, dealerships are the most expensive way
to go for most things. Some people like them. Some don't.
Old 03-31-2008, 06:06 AM
maherov's Avatar
Mobil 1 all the way
Old 03-31-2008, 06:20 AM
ORIGINAL: EVILWEELEE
Evil, you done good! This is the correct oil for the engine as it meet the MBz quality standard rquired by your engine - - refer to your Owner's Manual for further detail.
Enjoy!
Old 03-31-2008, 12:52 PM
will3hawks's Avatar
0W40 Mobil 1 is a good choice, however the shop I go to uses 5W40 Pentosynth which is a German synthetic. Probably worth consideration. Some dope had put 5W30 Castrol Synthetic blend in my car and it went through the engine like **** through a tin horn. Since changing to the Pentosynth I no longer use oil[/align][/align]Regards,[/align][/align]Will[/align]
Old 03-31-2008, 05:25 PM
EVILWEELEE's Avatar
THANKS FOR ALL THE ADVICE GUYS, THIS FORUM IS GREAT.
  #9
Old 04-21-2008, 10:23 AM
0w-40 all the way and its the same price anyways, so its not like ur going 2 save money using anything else.
rx7pro
05-03-2009 07:45 PM
skatyal
03-19-2007 05:14 PM
rcend
12-12-2006 11:30 PM
BenzoDJ
03-13-2006 01:14 AM
jheese
09-04-2004 09:56 PM
Quick Reply: ENGINE OIL C280
