emergency brake cable(passenger side)replacement! HELP
Old 02-16-2009, 10:56 PM
brudd's Avatar
Default emergency brake cable(passenger side)replacement! HELP
I need to replace the emergency brake cable on the passenger side. Everything inside the hub was in pieces except for the shoes. When i replaced the shoes, and springs the rotor wouldn't go back on even with the adjustment down to nothing. I figure it's the expander on the end of the cable that's attached at the end. Can i pull that out if I disconnect the cable under the car? There doesn't seem to be enough room between the hub and the end of the cable opening slot to get it through. Help.
rgengr
05-27-2008 09:44 AM
rosenfe
03-19-2008 07:46 PM
brudd
07-17-2007 10:06 PM
Scuddog
07-09-2007 06:26 PM
Homer1212
05-31-2007 12:58 AM
Quick Reply: emergency brake cable(passenger side)replacement! HELP
