C350 Coupe SE paddle shift upgrade ?
Old 10-31-2010, 08:29 AM
350_Coupe's Avatar
Default C350 Coupe SE paddle shift upgrade ?
I'm about to take the plunge on a 2005 C350 SE Auto Coupe (UK model) but as you all know, when buying second hand your kind of limited in the options dept, to what the original buyer selected.
Well the one i have my eye on does not have the paddle shift on the steering wheel, although it does have the 7G auto transmission, and the mode selection switch next to the shifter has only C and S on it, no M option
So my question, if armed the correct steering wheel with the paddles fitted, is it possible to retro fit the paddle shift option ? if so what's needed, except the obvious of the wheel and possibly the mode switch (i'm assuming it's actually the same switch just different markings) .... is it then a software update that's needed ?
TIA
Old 01-27-2011, 07:25 AM
abdalim's Avatar
TIA
hi, did you manage to retrofir paddle shift steering to your c350. If so how did you go about and if possible I also like do the retrofit as well
Old 02-07-2011, 01:21 PM
350_Coupe's Avatar
Hi, sorry for the really slow reply, this one snuck past me ...
I have not done it yet, however i will be doing.
You need to source a suitable steering wheel, and then have that fitted, and the Car's ECU reprogrammed with a STAR machine to recode it and enable the manual shift option, the little button that has "C-S" on it will work just fine, but can be swapped for one that says "C-S-M" if you wish.
For me here in the UK, COMAND Online will remove the old wheel and fit the new Steering Wheel and recode the car for about £200
Sourcing the exact one you want however can be tricky, as there are a button style and a paddle style, i am currently looking at SLK ones SLK R171 for example will fit, accept the airbag and switches i have and will accept the AMG aluminium paddles too if i want
acicero
09-14-2014 04:33 PM
Coup4Dave
10-17-2012 06:58 AM
Mani22
03-08-2011 12:03 PM
Link2005
08-24-2005 01:28 AM
Quick Reply: C350 Coupe SE paddle shift upgrade ?
