C280 surging at idle
Old 06-03-2009, 04:44 PM
Hot Rod Ron's Avatar
Default C280 surging at idle
I have a 94 C280 that surges between 500rpm-1000rpm and slight misfire. It smells rich but I don't have a scan tool to read the Oxygen sensor. Is thier a way to read the O2 without a scan tool?
I have replaced the problem engine wiring harnes.
Old 06-03-2009, 05:09 PM
chassis221's Avatar
usually caused by a vacuum leak. spray carb cleaner around all the areas and itll help find leaks. check all the vacuum lines, plastic and rubber. air mass sensor can do that too. dirty throttle body too.
Old 06-13-2009, 04:25 PM
09CivicSiBrian's Avatar
Could also be the Mass Air Flow sensor in the intake path.
B
MWK220
06-02-2010 09:25 PM
psychotuner
06-22-2009 06:34 PM
oregonboy
05-02-2008 06:18 PM
Turborado
04-09-2007 12:29 AM
Turborado
04-02-2007 07:43 PM
Quick Reply: C280 surging at idle
