C240 power rear window shade and fuse box
Old 08-31-2007, 09:15 PM
getajet's Avatar
Default C240 power rear window shade and fuse box
hi guys, new to this forum and i read through alot of it and it looks great. hope i can be of help in the future but i just bought my car (2002 C240 6spd....love it). two issues to start with:
1- the power rear window shade does not work. when i engage the switch, i hear a soft click from back there, but nothing happens. i cant find the fuse which brings me to
2- where the f is the fuse box? the manual says inside the drivers door on the side of the dash, but all that is there is a panel with no way to remove it; it looks just like the other (passenger) side. i tried to take it off but i was afraid to damage it; it wont come off. i spent an hour searching the car.. i found the one in the engine compartment and in the trunk, but they are small and have no reference sheets?
maybe someone has had an easy fix or knows of a common fix for the window shade, and where my fuse box is? thanks!!!!
Old 09-01-2007, 08:45 AM
Default RE: C240 power rear window shade and fuse box
The one on the driver side should have the reference sheet.The leading edge towrds you should release with enough pressure.
Old 09-01-2007, 09:22 AM
getajet's Avatar
thanks.. but how do you open it then? the manual shows a little indentation to grab onto; this one is flush. i have spent alot of time trying to rip it off of there, and am really afraid of damaging the car. i am not going to start prying it with a screwdriver! any help is appreciated; there must be a technique if this really is the fuse box.
Old 11-26-2010, 12:42 PM
jravort's Avatar
It opens pretty easy with screw driver and go's back on easy, I need the diagram to, my sun shade won't work I need to find a diagram if anyone can help. 2005 c240
Old 11-27-2010, 09:19 PM
81first's Avatar
I nhave one in my fuse box I will scan it tomorrow and can email it if you would like or post it here if I can figure out how to do it
Old 11-28-2010, 12:42 PM
jravort's Avatar
Thanks my email is ravort@hotmail.com contact me if its easy and you want to fax it to me
Old 11-29-2010, 01:11 PM
jravort's Avatar
I went to another Mercedes dealer and he got the diagram for me
Old 11-29-2010, 02:08 PM
rgh's Avatar
rgh
rgh is offline
getajet: put a flat-bladed screwdriver in between the side panel and the dash; move the panel towards the door about two inches to clear the snap in retainers; then pull the side panel straight back. It sounds harder than it is & once you get the panel off, you will see...
  #9
Old 12-04-2010, 02:12 PM
jravort's Avatar
FYI After looking at the fuses for the Sun screen from the diagram I got from the dealership and the the fuses were good, I decided to pull all fuses found one bad #12 replaced it. sun screen and rear A/C outlet works fine.
Horseshoe
04-29-2015 09:22 AM
dkamlan
02-01-2008 12:03 PM
Breneman84
01-01-2008 02:23 PM
awg001
12-12-2005 04:09 AM
hawke
11-14-2005 01:35 PM
Quick Reply: C240 power rear window shade and fuse box
