C230 kompressor...oil change - Page 3 - Mercedes Forum - Mercedes Benz Enthusiast Forums
Thread Tools Search this Thread
  #21
Old 09-13-2010, 03:25 PM
Default RE: C230 kompressor...oil change
I have a 2004 MB C230K. Just bought it 6 months back and it time for an oil change. I did call the dealer and they quoted me around $250 + taxes for Service A which covers oil change...
I called a couple of places for oil change and Kwik car care do the same oil change for $60 using Mobil1 synthetic oil. But they use aftermarket oil filter....
My question is - Is it ok to use a aftermarket oil filter or should I use the original from Mercedes Dealership? If I have to use original from MB dealership then can I buy 2 and have them stocked so that I dont have to keep going to the dealership to buy these filters...
-Z
  #22
Old 09-14-2010, 03:44 PM
I would buy MB Filter because it comes with the 3 o-rings you need for it. The aftermarket may not come with them and you should always change O-rings when doing new stuff. I would also get the copper washer that goes on the drain plug bolt. All this stuff is under $20. I am actually about to go get another filter. My 5K mile mark is up. Shes 100 miles shy of 80K miles. Make sure you get Mobile1 0-40 Full Synthetic for the Kompressor motor. Auto Zone they are about $7 each and I am pretty sure our motors hold 5.8qrts.
Hope that helps.
FYI - My Local MB dealership in Brentwood, TN has FREE 63-point inspection this month if anyone is close. $105 value.
Thread Thread Starter Forum Replies Last Post
Supercharger (Kompressor) Oil Change DIY gauthier613 Mercedes C Class 0 07-04-2008 07:16 PM
05 c230-oil change, resetting oil timer, and getting a extended warranty? floresadolfo1 Mercedes C Class 1 01-26-2007 04:15 PM
C230 Kompressor oil blowback/ Mobil M synthetic oil drblank Mercedes C Class 2 01-09-2007 10:33 PM
Oil Extractor oil change RockSolid General Tech 0 06-24-2006 06:41 PM
Tags
05, 2002, 2004, 2005, benz, c230, changing, dealership, grade, kompressor, mercedes, oil, service, tips, type, types
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
