Mercedes Benz Forums
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Mercedes C Class
Sign in using an external account
Register Forgot Password?
Search
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Mercedes Forum today!
LinkBack Thread Tools Search this Thread
Old 10-28-2006, 10:36 AM
Default Battery Drain Problem
Need help! Battery 2001 C320 drains to zero if not driven every day. Thought bad battery, installed new battery, but still have same problem. Car starts runs and drives ok if driven everyday. Can't find anything staying on in car (lights ect). Disconnected battery ground cable and hooked Volt/Ohm meter in line and measure 12.2 volts drain with everything off key out and doors closed. Any ideas? Car recently purchased, could have been an ongoing problem.
Register today for free or log in if already registered to remove this ad!
Old 10-29-2006, 05:19 PM
Default RE: Battery Drain Problem
Do a search for battery problems. A number of posts have indicated power seats may be a drain if wiring faulty, that is if you have power seats.
__________________
2012 BMW 535i X-drive
Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 2003 BMW 325iT, 2002 CL230 Sport Coupe, 2008 BMW 535i
Old 02-13-2007, 03:28 PM
Had same problem with my 2001 c320
purchased new battery but it would be dead if I did not drive it every day.
Took it to dealership and they found that the power seat was draining the battery.
Replaced power seat control module...final cost ~555.00
did anyone else have the same problem??
Old 02-13-2007, 05:12 PM
This appears to be a common problem w the C320. Mine is a 2001 C320. But new batteries are pratically dead. You have to drive the car for some time (a full day?) to charge up the new battery. Its like buying a new cell phone. The battery is new and has some power but you have to charge it up to use its full potential. Initially, I thought my alternator was at fault. No problems now.
A friend of mine recommended that I buy a charger to maintain the battery when the car is in the garage for long periods. I've seen some "smart" chargers that automatically disengage if the battery is full. This would seem to be a cheaper alternative than to have MB charge you for the initial diagnosis plus more $$$ for the labour and part replacement - if any.
Old 02-23-2007, 03:44 PM
so after the power seat control module is replaced the battery power stays sustanined. ALSO are there control moduals for each seat or just one
[align=left] [/align]
Tags
2005, battery, benz, charge, drain, draining, driven, everyday, issue, key, mercedes, power, problem, r350, seat
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
