2003 c230 won't lock doors
Old 05-03-2011, 08:03 PM
zoober's Avatar
Default 2003 c230 won't lock doors
The key fob will start the car but will not lock or unlock the doors the panic button will not work. Just replaced the batteries but didnt help. Anyone else have this problem.
Old 05-03-2011, 08:10 PM
chassis221's Avatar
first is the red light lighting on the remote when you push buttons? could be the anteena on the back window. is it tinted?
Old 05-04-2011, 01:04 PM
cario's Avatar
Unhappy similar problem on C240 estate
yep, I have to take the key out to manually unlock driver door (central not working) but electronic fob does start ignition. There is not indicator light on key fob and the manual central lock button on the dashboard works, as does the automatic locking when car reaches 9mph. Does this most of the time now but does, once in a while, work again!
Old 05-04-2011, 04:23 PM
zoober's Avatar
Yes the red light is blinking and yes just had the car retinted sat. never knew the antenna was in the back window thought it was infared. Where is the antenna located at in the window or is it part of the defrost?
Old 05-04-2011, 05:35 PM
chassis221's Avatar
above the rear glass under the headliner. if you look under the headliner by pulling it down a little youll see a black plastic piece across the top of the glass that is your "com bar" antenna. this is for a sedan not a coupe. if you have a coupe the combar is above the glass in the reat lid.
no remote locks are radio frequency but can use infrared if needed. so if you got tint that is your problem.
Old 05-05-2011, 02:57 AM
zoober's Avatar
Thanks for the info will take care of that problem
Old 09-21-2012, 11:35 AM
bunny's Avatar
Default central locking
I have the identical problem , fob works when it feels like it, checked all fuses and central locking works on dash, no red light on fob though?
Whats next to check please?
Old 09-21-2012, 02:34 PM
bunny's Avatar
Has anyone fixed this problem ?
jason7570
01-04-2013 01:47 AM
Goldengirl1
11-08-2012 07:28 PM
Srazz01
06-13-2011 09:44 PM
cobrar320
09-07-2009 05:27 AM
alruff
12-08-2007 09:05 AM
Quick Reply: 2003 c230 won't lock doors
