2000 c230 fuel pump? location - Mercedes Forum - Mercedes Benz Enthusiast Forums
LinkBack Thread Tools Search this Thread
Old 12-14-2008, 11:34 PM
Default 2000 c230 fuel pump? location
Can anyone tell me where the heck the fuel pump is located in this car. Is it in the fuel tank? Help! C230 Fuel Pump 2000'
Old 12-15-2008, 03:36 PM
Default RE: 2000 c230 fuel pump? location
Yes, and it's not a job you want to do at home in your garage either.
I just had this done, as you might have seen me post about it.
EXPENSIVE little devil, too. Labor is high as well.
Be sure to have them (or you) check the fuel pressure up at the engine (easily done) to pinpoint the need for a new
pump before you have to take out a second mortgage on your home to have one put in.
PS>mine lasted 146K miles. When they go, they go. The car will not run. And they go suddenly.
Old 12-15-2008, 06:27 PM
chassis221's Avatar
i can help you out. i live in fort washington, get back to me if interested. I sent you a PM message too
Thread Thread Starter Forum Replies Last Post
Fuel pump relay and fuse location lighting777 Mercedes C Class 7 10-30-2015 05:32 AM
Fuel Pump Location Pensmerc General Tech 5 09-30-2008 01:39 AM
450 sl fuel pump relay location hapaschold Other 1 10-05-2007 06:59 PM
Fuel Pump Relay Location petroff Mercedes S Class 1 05-03-2007 10:05 PM
Location of Crankshaft Position Sensor and Fuel Pump Relay-01 E320 BenzoDJ Mercedes E Class 3 03-30-2007 09:01 PM
Tags
06, 2000, 230, c230, change, check, fuel, instructions, location, mbz, mercedes, place, pressure, pump, replacement
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
