1995 C220
Old 06-28-2005, 11:24 PM
edpayne's Avatar
Default 1995 C220
I have had some fuel sensor problems in the past, it feels as if my newest problem might be related and I would like to know if anybody has had the same problem. The idle has always been rough and it seems too low, but the latest is a problem that has stopped me from driving it, today. The engne won't run at a constant speed the car if you bear down on the pedal the car abruptly goes fast then slow, up and down....
Anyone had this happen to them?
Old 06-29-2005, 02:06 AM
SL600_Cruzin's Avatar
Default RE: 1995 C220
Please list a bit more about the car's history.
Has it had a tune-up in a while ? Fuel Filter, Air Filter Replaced & when ?
There's several things that could be causing the problem you're describing.
When you say "The idle has always been rough and it seems too low, but the latest is a problem that has stopped me from driving it, today." do you mean that it started running rough then died completely and won't start again ?
If you give us a bit more feedback we may be able to help.
TJ
Old 08-25-2015, 09:02 PM
Wallyworld's Avatar
I had an unsteady idle that went away when I had the mass air flow sensor replaced. Hope this helps.
Uneek
08-31-2005 08:00 AM
jimb96
05-04-2005 01:31 AM
kirr45
03-06-2004 10:10 PM
joeyc220
02-20-2004 11:48 PM
LiftedDisco
01-21-2004 04:06 PM
Quick Reply: 1995 C220
