My 1971 Mercedes B250 6 cyl in-line
Hi Guys,
This 2dr, 6 cylinder coupe is set up with Twin 4 bbl carbs
I think they're Webers
We've cleaned the carbs, installed new plugs, new wires, points, and coil, and cleaned the gas tank, -but when it starts it's running rough.
After running for less than 20 minutes, it get rough then stalls out.
We checked everything and..our new points are burned already.
We replaced them and it happened again !
My Mercedes guru ( he has 4 M-B's, and does his own work & mine), says we should go with a new Electronic Ignition system.
Q: what do you believe is the problem right now ?
Q: will the Electronic ignition solve the problem ?
Any help is very much appreciated.
Thanks,
trueman
Thanks,
trueman
Kevin Rattai
10-02-2013 04:56 PM
aztectt
07-06-2007 11:43 AM
edwardwright
01-05-2005 12:23 PM
kcidmusic
01-03-2005 11:31 PM
