Mercedes AMG Class All AMG Models.
problem with comand center
Old 04-26-2007, 01:30 AM
navest's Avatar
Default problem with comand center
Anyone experience this? I've got an '06 S55 and yesterday everything in the comand center just stopped working. The screen lights up when you hit 'power' but then after a few seconds it says "SYSTEM UNAVAILABLE" then it turns off. Doesn't matter if you try radio, CD, Nav, Service, Phone, etc. I tried resetting it from the service menu (had to race through the selections before the error message appeared) but it didn't help. Any advice would be appreciated.
thanks!
Old 04-13-2014, 02:21 AM
VancouverS55's Avatar
Default Same problem
I am having same problem with my 04 S55. Anyone out there?
Old 09-03-2014, 12:17 AM
Default Command Center
Works off and on - back to off - comes up 'unavailable" and powers down.
Hoping someone out there might have gone through this and fixed it. I did try the battery disconnect.
Old 09-03-2014, 10:20 PM
chassis221's Avatar
thanks!
Sometimes pulling fuses for the radio will get the radio working but you could also go to a dealer and a software flash that should fix the problem.
Doing a RESET in the cluster only resets customer settings to default such as seat, radio tuning, mph/km, and other radio settings. It has nothing to with hard resets to the engine or trans.It doesn't clear codes or reset the computers.
Old 11-15-2014, 02:40 PM
FOG's Avatar
FOG
FOG is offline
Default Command center
I was warned about disconnecting the battery in my 04 SL55 ,by the tech. Said you need to power down all the system sensors before doing so ,or they will go into default mode and eventual put you in limp home mode.
Your fix is going to be a re boot of your whole car, by MB or a shop equally equipped with the factory software.
FOG
Old 03-13-2017, 01:07 PM
osprey55's Avatar
Default System Unavailable
Did you get the "system unavailable" problem fixed? If so, what was the problem? I am having the same problem with my 05 SL500.
navest
01-03-2024 12:07 PM
schumicat
11-17-2016 12:18 PM
mirage6976
02-09-2006 01:55 AM
edl100
01-16-2006 03:08 AM
1stXmbOwner96E320
10-30-2005 05:35 PM
Quick Reply: problem with comand center
