K1 Motorsport HRE | BRABUS | Lorinser | RennTech | KLEEMANN | Carlsson | H&R | Bilstein | AMG | iceLink Pro | OEM and more.
Rear Camber Kit
Old 01-02-2008, 10:47 AM
K1MOTORSPORT's Avatar
Default RE: Rear Camber Kit
They don't make it for ML/GL.
ORIGINAL: itz16v
Do makethe camber kit for a 08 W164 ML350?
  #12
Old 07-30-2008, 06:38 PM
These are very rare kits. We have 5 sets available. 1st come 1st served!
  #13
Old 11-19-2008, 02:16 AM
I have a 2004 C230 Kompressor. Will this Camber kit fit my car?
I want a set for the rear if it does.
officerkeaton@yahoo.com
  #14
Old 12-01-2008, 01:35 PM
ORIGINAL: akeaton
This item is no longer available. Thanks.
  #15
Old 12-17-2008, 12:21 PM
oiler's Avatar
How about adjustable arms for 83 300SD??
  #16
Old 08-24-2009, 08:52 PM
plbrown's Avatar
Will this kit fit my 2003 e320 W211
  #17
Old 09-01-2009, 03:39 PM
indymech1's Avatar
Hello Can you tell me where Get these kits
  #18
Old 09-24-2009, 07:54 PM
GLK4matic's Avatar
MB Arts has adjustable rear camber arms that are made out of 1" diameter 7075 aircraft aluminum and use QA-1 rod ends as well. They can be extended 1 3/8" to correct the camber issue MB's have. They are on Ebay right now for $340.00.
  #19
Old 09-25-2009, 06:22 AM
indymech1's Avatar
Default Camber kits
Thanks for the info! Went with the adjustable bushings instead-Spc its an AMG 55 cabrio slight lowering done (H and R springs) not much you can do that has not already been done.
  #20
Old 09-27-2009, 10:08 PM
GLK4matic's Avatar
No problem! I am just giving info for those who need a fix for their camber problem that can't be fixed by factory camber bolts.
Quick Reply: Rear Camber Kit
