CIGARETTE LIGHTER - Mercedes Forum - Mercedes Benz Enthusiast Forums
Thread Tools Search this Thread
Old 06-14-2005, 05:24 PM
Default CIGARETTE LIGHTER
THE CIGARETTE LIGHTER IN MY CAR [E420] NEVER BEEN USED. STILL BRAND NEW. I GUESS THE OWNER BEFORE ME WAS NOT A SMOKER OR ALLOW ANYONE TO SMOKE IN THIS CAR.
I PUSH IN THE CIGARETTE LIGHTER BUT IT DOES NOT WORK. I AM ASSUMING THAT THE FUSE MAY NEED A REPLACEMENT. DOES ANYBODY KNOWS IF THE CIGARETTE LIGHTER HAS ITS OWN FUSE ALONE OR SHARE SAME FUSE WITH OTHER STUFF?
WHERE CAN I FIND THIS FUSE TO CHECK IT OUT?
THANKS
Old 06-15-2005, 11:21 PM
pbk pbk is offline
Default RE: CIGARETTE LIGHTER
My ashtray and lighter have never been used. Lighter doesn't work. Removed the ashtray, lighter comes out with it. on the left side of the ashtray are two contacts which I assume are for the lighter current. Mine are corrodid even though everything else looks brand new. I don't think it's worth the work to clean. Oh! on my 86 300SL
Old 06-16-2005, 11:24 AM
Thanks. I noticed that when I push in the lighter, I have to hold it for a while and pull it out manually, then its warm enough to light a cigarette.
What I want to do again, is to try vacuum cleaner in the outlet to see if it works. I will also try and check what you recommend, probably there is not too much wire contacts.
Old 10-26-2005, 02:25 PM
Stop smoking, then you can enjoy your Mercedes longer
Old 10-26-2005, 05:17 PM
Thanks but I need to plug in my GPS when purchase. The lighter is working when GPS was plugged in. The problem is the lighter itself which I DO NOT want to REPLACE.
Thread Thread Starter Forum Replies Last Post
cigarette lighter.... Danski Mercedes C Class 1 02-03-2006 05:30 PM
cigarette lighter Danski Interior 0 02-03-2006 01:41 PM
CLK 2000 Cigarette lighter jrmassie1 Mercedes CLK Class 1 06-07-2005 04:54 AM
How do I remove the cigarette lighter from my 2000 clk 430? albfamily Mercedes CLK Class 2 05-09-2005 06:00 PM
How do I remove the cigarette lighter from my 2000 clk 430? albfamily Audio/Visual Electronics 0 05-06-2005 06:00 PM
Tags
benz, c200, cigar, cigareete, cigarette, cigerette, class, doesnt, fuse, lighter, mercedes, mrecedes, remove, sl, work
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
