03 E500 Air Suspension
Old 03-31-2012, 05:49 PM
ERIC WOODS's Avatar
Default 03 E500 Air Suspension
got an E500 rear l/h airbag went bad replaced both rear airbag springs new compressor & compressor relay, car will not inflate airbags or lift rear anyone ever come up with this problem in the past,dont know what to do next
Old 03-31-2012, 06:12 PM
chassis221's Avatar
might have to clear codes first. might need MB computer to clear codes. and activate air suspension. can you hear the airmatic pump running?
Old 04-01-2012, 03:52 PM
ERIC WOODS's Avatar
Default 03 e500 air suspension
no airmatic pump does not run something seems missing as afar as juice to power pump,can make the pump run by powering directly have checked relays & fuses we did replace the airpump relay with genuine MB part the air springs are identical to what came off it Bilstein's
arnottdoug
04-20-2015 02:07 PM
arnottdoug
04-20-2015 02:05 PM
HondaWhisperer
06-17-2011 10:47 AM
domnvic
06-07-2009 02:33 AM
Mike456
04-07-2008 11:53 AM
Quick Reply: 03 E500 Air Suspension
