problems with wis asra
hello Im Roebrto from argentine i have a mercedes benz coupe 230 ce 1981 w123. ia a bought the program wis asra in canada. my problem is that this program only works with windows 2000 profesional servicepack 3 or less and in didnt get it. some knows a patch for this version for windows xp
thanks very much, in my country there aren`t a lot of mercedes and its very dificult to find information about all the mecanics problems. then i buy this manuals but i couldnt use it please help me
thanks again
thanks again
RE: problems with wis asra
Even though it says that, it will work fine on XP. It is very tricky to install and very easy to have problems. First thing, did you install the loopback adapter before you even started the install process? If not, you try uninstalling everything, reboot, install loopback adapter, reboot (important), then reinstall. You need to remove all entries in the Windows registry to really uninstall things. There was a link I found from one of the sellers that explained how to do it but unfortunately I did not bookmark it. If you can do a system restore to a point back before you installed or have something like ghost, that would be the most complete way to do it.
qwerty0987654321
Date 4/20/2007 11:39:14 AM
Can some one please give me the serial number for Mercedes Benz WIS/ASRA 2006.
Inform meLAN_IDyour computer and I shall give you a key to the program!
I can as to make keys to programEWA net (WIS \EPC net)
The instruction on installationEWA netit is possibledownlodfrom here:
http://rapidshare.com/files/21893344...lisch.rar.html
My Email vevika@yandex.ru
Hi Roberto, mercedes das and wis is only difficult to install if you don't know how to to it!
Getting information on a proper installation can be a pain in the neck.
I've created a website where you can download video guides on how to install mercedes wis ( wislite) and mercedes DAS onto your pc or laptop. XP or windows proffesional will be just fine, and if you should have a problem with the installation just send me an email through the website www.jcrecordings.com
