Pesky messages - Mercedes Forum - Mercedes Benz Enthusiast Forums
Thread Tools Search this Thread
Old 08-18-2010, 09:42 PM
Default Pesky messages
I have a 2004 E320. I am a DIY
How do I erase/reset the pesky messages that keep popping up at startup even after service has been performed?
Like:
"brake service required" (I've changed brakes and wear sensors)
"service required exceeded by xxxx miles",etc
I'm also getting a red battery-"visit workshop".. display, checked the battery and alternator and they work/read fine, any ideas?
Old 03-13-2017, 01:54 PM
Like:
turn key to on position and push cursor up or down until you see service exceeded by xxxx miles then press and hold reset button on side of dashboard. If you replaced the brake wear sensors correctly then light should go off automatically. Check to see if you have more than 1 wear sensor.
Thread Thread Starter Forum Replies Last Post
Pesky messages ferranrico Mercedes E Class 8 08-21-2010 08:58 AM
C230K W/57000 miles. Error messages. stevec230k Mercedes C Class 3 01-10-2010 11:19 PM
"Front marker light left" & "right" messages sea_bird200 Mercedes E Class 2 09-26-2008 08:37 PM
Esp and Headlight messages E500newbee Mercedes E Class 1 01-01-2008 11:19 PM
Clear messages on the message board Sprint97 Mercedes Benz Forum Help & Suggestion Center 1 04-18-2006 10:43 PM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
